February 11, 2025
SmartPresenceDetectionKit_LnA_1.0.0 on raspberry pi
Hi
I am trying to use this on a raspberry pi4 running ubuntu 2404. I am able to run make successfully but on trying to run the generated binary I get
./spdkit error while loading shared libraries: /lib/aarch64-linux-gnu/libc.so: invalid ELF
I don't know what to do to fix it. I did not install the linaro toolchain as I was not cross compiling - is that likely to be causing this error ?
I tried it on RPI 4b ubuntu 20.04 and didn't get your problem. Here is the info on my side.
raspberrypi@ubuntu:~/SmartPresenceDetectionKit_release$ ldd ./spdkit
        linux-vdso.so.1 (0x0000ffff86dab000)
        libspd.so => /home/raspberrypi/SmartPresenceDetectionKit_release/SPD/Lib/lib64/libspd.so (0x0000ffff86d00000)
        libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000ffff86c50000)
        libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000ffff86a90000)
        /lib/ld-linux-aarch64.so.1 (0x0000ffff86d6e000)
raspberrypi@ubuntu:~/SmartPresenceDetectionKit_release$ file /lib/aarch64-linux-gnu/libc.so.6
/lib/aarch64-linux-gnu/libc.so.6: ELF 64-bit LSB shared object, ARM aarch64, version 1 (GNU/Linux), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=1d7249a4f207d07166ff4be43acdc68a01faaa04, for GNU/Linux 3.7.0, stripped
According to your info "the “libc.so: invalid ELF”. Maybe it’s because of a damaged libc and you need only reinstall the system.
