GetSignalRate is returned MegaCountsPerSecond. So, if you ran with a timing budget of 30ms and got one number, you should get the same number if you changed to 60ms.
If you want to compare the signal strengths, you really need MegaCountsPerSecond PerSpad.
The sensor has 256 SPADs (Single Photon Avalanche Diodes) and if the signal is strong, we will turn off a lot of them. And some are occluded, so the max count will not be an integer to account for those partial SPADs.
I'm not sure I get 1Mhz from this.
But the sensor works best with 20MegaCounts, and above this is will start turning off SPADS. Below this all of them will be activated.
20Megacounts with 200 SPADs = 0.1MCountsPerSecondPerSpad.
You control the signal strength by having a more reflective target and a closer target. If you have too much signal, simply move the target farther away, or choose a less reflective (less white) target.
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
