MErro.1
Recommended reflective tape and collimating lens for ToF sensors?
Hi!. We are developing a distance measurement solution and are planning to use the VL6180v1 and/or VL53L4CD Time of Flight sensors. Due to our application conditions we need to identify the position of a very specific spot surrounded by a lot of metal and other reflective surfaces, so that we need to use a reflective adhesive tape and maybe a lens to reduce the Field of View of the sensor. Has anyone used any of those two elements? Any recommendations on the subject?
Thank you
Anne BIGOT
Hello !
The 3M reflective tape is also known as retro-reflective tape. It will work great for this application as all the photons coming to this tape will reflect exactly back to the center;
Putting a lens or any optical element over the sensors is discouraged. It could invalidate the eye safety. One could build a blinder (a bit of opaque material with a very small hole on it) but please don't put a lens on it.
Anne
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
MErro.1
MErro.1Author
Ok, I will try with the 3M tape. Thank you for your quick answer
Maria Jose
Anne BIGOT
When your question is answered, please mark this topic as answered by choosing Select as Best for the favorite answer. This will help other users find that answer faster.
