Divesh Dutt
Printing Garbage Value
Hi there,
I am working with tfmini lidar and i am using USART3.However i am getting the garbage in the virtual port any idea how can i resolve this but i am getting the right header i.e YY in decimal.
Any suggestion would be appreciated.
John E KVAM
John E KVAMBest answer
After much conversation, this is not an ST part. It's from Sparkfun, but based on an LED emitter and photo diode.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
raptorhal2
Lead
April 29, 2021
TeslaDelorean is correct. Read the data sheet for this device.
Each 8 byte data frame starts with a 0x5959 which happens to be ascii YY, but the remaining bytes are binary. Either convert the binary to ascii before sending to Tera Term, or use a terminal emulator that provides for a hex display that is easier to interpret than garbage.
The literature says the comm is USART/I2C. USART seems to be the default.
Cheers, Hal
Divesh Dutt
Oh ok what you saying is tera term doesn't support the binary number.I didn't know that.i'll try another emulator or will convert it to hex.
John E KVAM
What is the part number of the sensor you are using?
John E KVAM
