P-NUCLEO-53L8A1
I ordered / received the P-NUCLEO-53L8A1 development kit to evaluate the VL53L8CX ToF sensor.
It includes:
X-NUCLEO-53L8A1 Time-of-Flight expansion board based on the VL53L8
series for STM32 Nucleo
• NUCLEO-F401RE development board
Could someone possibly point me to a quick-start guide?
Thanks in advance!
John E KVAM
John E KVAMBest answer
It's easy - sort of...
Download the evaluation code that runs the Eval kit, and install it on your PC. Once the code is installed on your PC, simply run it. There will be an 'about' tab that contains the user manual. And it's that user manual that will get you going.
Code is:
STSW-IMG041
P-NUCLEO-53L8A1 pack graphical user interface (GUI)
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
Code is:
STSW-IMG041
Anne BIGOT
There is also a quick start guide here : x-nucleo-53l8a1-quick-start-guide.pdf
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
