Anne BIGOT
Nov 19, 2024 3:35 PM UTC
My Global Shutter camera doesn't seem to work
I bought a STEVAL-55G0MBI1, which is the VD55G0 S-Board eval kit.
Trying to output the image to my PC, nothing is coming out.
What could be the issue with my setup?
John E KVAM
John E KVAMBest answer
Nov 19, 2024 3:40 PM UTC
The cameras work - we've tested them. And PCs are pretty reliable.
That leaves the cable.
YOU NEED A USB C 3.1 CABLE.
Amazon.com has one described as:
USB A to USB C 3.1/3.2 Gen 2 Cable 10Gbps Data Transfer (6inch/0.5FT), Short USB C SSD Cable with 60W QC 3.0 Fast Charging, Spare Cable for Samsung T7, SanDisk Extreme Portable SSD, Crucial X8, WD
for only $7.00
USB 3.2 works too.
The reason is that the older USB C cables are only rated to 480MBits per second. That's too slow for the next generation of cameras. USB 3.1 is 5Mbits and 3.2 is 10Mbits
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
for only $7.00
USB 3.2 works too.
