Dec 15, 2024 4:18 PM UTC
Linux Start Guide for ST BrightSense - Errors on RPi5
I am following the linux-startguide-stbrightsense for the Raspberry Pi 5 (with a clean build of RPi OS Lite, where I only had to install the i2c regmap), and I have come across some problems in the tutorial. I am using two VD66GY cameras, with the entire S-board kit. Hardware connection is OK, as I get I2C communication and I can detect them both via the i2cdetect on i2c4 and i2c6.
I have put both dtoverlays together, as I have both cameras plugged in (basically the same thing except changing some names for conflict reasons):
// SPDX-License-Identifier: GPL-2.0-only
/dts-v1/;
/plugin/;
	compatible = "brcm,bcm2835";
	fragment@0 {
		target-path="/";
		__overlay__ {
			camera_clk_12M: camera_clk_12M {
				#clock-cells = <0>;
				compatible = "fixed-clock";
				clock-frequency = <12000000>;
			v1v2: v1v2 {
				compatible = "regulator-fixed";
				regulator-name = "fixed-supply-1v2";
				regulator-min-microvolt = <1200000>;
				regulator-max-microvolt = <1200000>;
			v1v8: v1v8 {
				regulator-name = "fixed-supply-1v8";
				regulator-min-microvolt = <1800000>;
				regulator-max-microvolt = <1800000>;
			v2v8: v2v8 {
				regulator-name = "fixed-supply-2v8";
				regulator-min-microvolt = <2800000>;
				regulator-max-microvolt = <2800000>;
	fragment@1 {
		target = <&i2c_csi_dsi0>;
		__overlay__ {
			#address-cells = <1>;
			#size-cells = <0>;
			status = "okay";
			fox_0: fox@10 {
				status = "ok";
				compatible = "st,vd66gy";
				reg = <0x10>;
				clocks = <&camera_clk_12M>;
				clock-names = "xclk";
				vcore-supply = <&v1v2>;
				vddio-supply = <&v1v8>;
				vana-supply = <&v2v8>;
				reset-gpios = <&gpio 5 1>;
				port {
					fox_ep_0: endpoint {
						clock-lanes = <0>;
						data-lanes = <1 2>;
						remote-endpoint = <&csi_ep_0>;
						clock-noncontinuous;
						link-frequencies =
							/bits/ 64 <402000000>;
						lane-polarities = <1 1 1>;
	fragment@2 {
		target = <&csi0>;
		csi_0: __overlay__ {
			status = "okay";
			brcm,media-controller;
			port {
				csi_ep_0: endpoint {
					remote-endpoint = <&fox_ep_0>;
					clock-lanes = <0>;
					data-lanes = <1 2>;
	fragment@3 {
		target = <&cam0_reg>;
		__overlay__ {
			status = "disable";
	fragment@4 {
 target-path = "/__overrides__";
 __overlay__ {
 cam0-pwdn-ctrl = <&fox_0>, "reset-gpios:0";
 cam0-pwdn = <&fox_0>, "reset-gpios:4";
 cam1-pwdn-ctrl = <&fox_1>, "reset-gpios:0";
 cam1-pwdn = <&fox_1>, "reset-gpios:4";
 media-controller = <&csi0>, "brcm,media-controller?",
 <&csi1>, "brcm,media-controller?";
 fragment@5 {
		target = <&i2c_csi_dsi1>;
		__overlay__ {
			#size-cells = <0>;
			status = "okay";
			fox_1: fox@10 {
				status = "ok";
				reg = <0x10>;
				port {
					fox_ep_1: endpoint {
						clock-lanes = <0>;
						data-lanes = <1 2>;
						remote-endpoint = <&csi_ep_1>;
						link-frequencies =
 fragment@6 {
		target = <&csi1>;
		csi_1: __overlay__ {
			status = "okay";
			port {
				csi_ep_1: endpoint {
					remote-endpoint = <&fox_ep_1>;
					clock-lanes = <0>;
					data-lanes = <1 2>;
 fragment@7 {
		target = <&cam1_reg>;
		__overlay__ {
			status = "disable";
I am attempting to use the VD66GY camera, and the installation process appears to have gone alright, as per dmesg output:
[ 5.526019] rp1-cfe 1f00128000.csi: Using sensor vd56g3 11-0010 for capture
[ 5.526114] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-csi2_ch0] node id 0 successfully as /dev/video0
[ 5.526144] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-embedded] node id 1 successfully as /dev/video1
[ 5.526169] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-csi2_ch2] node id 2 successfully as /dev/video2
[ 5.527131] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-csi2_ch3] node id 3 successfully as /dev/video3
[ 5.527579] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-fe_image0] node id 4 successfully as /dev/video4
[ 5.527643] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-fe_image1] node id 5 successfully as /dev/video5
[ 5.527675] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-fe_stats] node id 6 successfully as /dev/video6
[ 5.527708] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-fe_config] node id 7 successfully as /dev/video7
[ 5.536428] vd56g3 11-0010: Successfully probe vd66gy sensor
[ 5.540065] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[ 5.542438] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 5.544853] Registered IR keymap rc-cec
[ 5.544901] rc rc0: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0
[ 5.544941] input: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0/input1
[ 5.546979] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc/107c701400.hdmi/sound/card0/input2
[ 5.548203] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
[ 5.551630] Registered IR keymap rc-cec
[ 5.551903] rc rc1: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1
[ 5.551987] input: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1/input3
[ 5.559750] rp1-cfe 1f00110000.csi: Using sensor vd56g3 10-0010 for capture
[ 5.559893] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc/107c706400.hdmi/sound/card1/input4
[ 5.560695] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-csi2_ch0] node id 0 successfully as /dev/video8
[ 5.565399] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-embedded] node id 1 successfully as /dev/video9
[ 5.565894] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-csi2_ch2] node id 2 successfully as /dev/video10
[ 5.566352] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
[ 5.569471] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-csi2_ch3] node id 3 successfully as /dev/video11
[ 5.569711] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
[ 5.570007] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
[ 5.574341] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 5.576890] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 5.577813] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-fe_image0] node id 4 successfully as /dev/video12
[ 5.580877] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-fe_image1] node id 5 successfully as /dev/video13
[ 5.581516] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-fe_stats] node id 6 successfully as /dev/video14
[ 5.581797] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-fe_config] node id 7 successfully as /dev/video15
[ 5.581963] vd56g3 10-0010: Successfully probe vd66gy sensor
Then, I try to follow the v4l2-ctl one liners:
v4l2-ctl --list-formats-ext --list-ctrls --list-ctrls-menu
ioctl: VIDIOC_ENUM_FMT
 Type: Video Capture
 [0]: 'YUYV' (YUYV 4:2:2)
 Size: Stepwise 16x16 - 16384x16384 with step 2/1
 [1]: 'UYVY' (UYVY 4:2:2)
 [2]: 'YVYU' (YVYU 4:2:2)
 [3]: 'VYUY' (VYUY 4:2:2)
 [4]: 'RGBP' (16-bit RGB 5-6-5)
 [5]: 'RGBR' (16-bit RGB 5-6-5 BE)
 [6]: 'RGBO' (16-bit A/XRGB 1-5-5-5)
 [7]: 'RGBQ' (16-bit A/XRGB 1-5-5-5 BE)
 [8]: 'RGB3' (24-bit RGB 8-8-8)
 [9]: 'BGR3' (24-bit BGR 8-8-8)
 [10]: 'RGB4' (32-bit A/XRGB 8-8-8-8)
 [11]: 'BA81' (8-bit Bayer BGBG/GRGR)
 [12]: 'GBRG' (8-bit Bayer GBGB/RGRG)
 [13]: 'GRBG' (8-bit Bayer GRGR/BGBG)
 [14]: 'RGGB' (8-bit Bayer RGRG/GBGB)
 [15]: 'pBAA' (10-bit Bayer BGBG/GRGR Packed)
 [16]: 'pGAA' (10-bit Bayer GBGB/RGRG Packed)
 [17]: 'pgAA' (10-bit Bayer GRGR/BGBG Packed)
 [18]: 'pRAA' (10-bit Bayer RGRG/GBGB Packed)
 [19]: 'pBCC' (12-bit Bayer BGBG/GRGR Packed)
 [20]: 'pGCC' (12-bit Bayer GBGB/RGRG Packed)
 [21]: 'pgCC' (12-bit Bayer GRGR/BGBG Packed)
 [22]: 'pRCC' (12-bit Bayer RGRG/GBGB Packed)
 [23]: 'pBEE' (14-bit Bayer BGBG/GRGR Packed)
 [24]: 'pGEE' (14-bit Bayer GBGB/RGRG Packed)
 [25]: 'pgEE' (14-bit Bayer GRGR/BGBG Packed)
 [26]: 'pREE' (14-bit Bayer RGRG/GBGB Packed)
 [27]: 'BYR2' (16-bit Bayer BGBG/GRGR)
 [28]: 'GB16' (16-bit Bayer GBGB/RGRG)
 [29]: 'GR16' (16-bit Bayer GRGR/BGBG)
 [30]: 'RG16' (16-bit Bayer RGRG/GBGB)
 [31]: 'PC1R' (PiSP Bayer Compressed Format, compressed)
 [32]: 'PC1B' (PiSP Bayer Compressed Format, compressed)
 [33]: 'PC1g' (PiSP Bayer Compressed Format, compressed)
 [34]: 'PC1G' (PiSP Bayer Compressed Format, compressed)
 [35]: 'GREY' (8-bit Greyscale)
 [36]: 'Y10P' (10-bit Greyscale (MIPI Packed))
 [37]: 'Y12P' (12-bit Greyscale (MIPI Packed))
 [38]: 'Y14P' (14-bit Greyscale (MIPI Packed))
 [39]: 'Y16 ' (16-bit Greyscale)
 [40]: 'PC1M' (PiSP Bayer Compressed Format, compressed)
It's missing BA10, which is necessary for the next step:
v4l2-ctl --set-fmt-video width=640,height=480,pixelformat=BA10
The pixelformat 'BA10' is invalid
(I'm guessing I need to use -d /dev/video0)
v4l2-ctl --set-fmt-video width=640,height=480,pixelformat=BA10 -d /dev/video0
I have used BA81 instead
v4l2-ctl --set-fmt-video width=640,height=480,pixelformat=BA81 -d /dev/video0
Same problem for the ioctls:
v4l2-ctl --set-ctrl auto_exposure=1 -d /dev/video0
unknown control 'auto_exposure'
I think this is the way the RPi5 implements these things:
media-ctl -d /dev/media2 -p
Media controller API version 6.6.62
Media device information
driver rp1-cfe
model rp1-cfe
serial
bus info platform:1f00128000.csi
hw revision 0x114666
driver version 6.6.62
Device topology
- entity 1: csi2 (8 pads, 8 links)
 type V4L2 subdev subtype Unknown flags 0
 device node name /dev/v4l-subdev0
 pad0: Sink
 [fmt:SRGGB10_1X10/640x480 field:none colorspace:raw xfer:none ycbcr:601 quantization:full-range]
 <- "vd56g3 11-0010":0 [ENABLED,IMMUTABLE]
 pad1: Sink
 [fmt:unknown/16384x1 field:none]
 pad2: Sink
 pad3: Sink
 pad4: Source
 -> "rp1-cfe-csi2_ch0":0 []
 -> "pisp-fe":0 []
 pad5: Source
 -> "rp1-cfe-embedded":0 []
 pad6: Source
 -> "rp1-cfe-csi2_ch2":0 []
 -> "pisp-fe":0 []
 pad7: Source
 -> "rp1-cfe-csi2_ch3":0 []
 -> "pisp-fe":0 []
- entity 10: pisp-fe (5 pads, 7 links)
 device node name /dev/v4l-subdev1
 pad0: Sink
 [fmt:SRGGB16_1X16/640x480 field:none colorspace:raw xfer:none ycbcr:601 quantization:full-range]
 <- "csi2":4 []
 <- "csi2":6 []
 <- "csi2":7 []
 pad1: Sink
 [fmt:FIXED/16384x1 field:none]
 <- "rp1-cfe-fe_config":0 []
 pad2: Source
 -> "rp1-cfe-fe_image0":0 []
 pad3: Source
 -> "rp1-cfe-fe_image1":0 []
 pad4: Source
 -> "rp1-cfe-fe_stats":0 []
- entity 16: vd56g3 11-0010 (1 pad, 1 link)
 type V4L2 subdev subtype Sensor flags 0
 device node name /dev/v4l-subdev2
 pad0: Source
 [fmt:SGRBG8_1X8/1120x1360 field:none colorspace:raw xfer:none quantization:full-range
 crop.bounds:(0,0)/1124x1364
 crop:(2,2)/1120x1360]
 -> "csi2":0 [ENABLED,IMMUTABLE]
- entity 18: rp1-cfe-csi2_ch0 (1 pad, 1 link)
 type Node subtype V4L flags 0
 device node name /dev/video0
 pad0: Sink
 <- "csi2":4 []
- entity 22: rp1-cfe-embedded (1 pad, 1 link)
 device node name /dev/video1
 pad0: Sink
 <- "csi2":5 []
- entity 26: rp1-cfe-csi2_ch2 (1 pad, 1 link)
 device node name /dev/video2
 pad0: Sink
 <- "csi2":6 []
- entity 30: rp1-cfe-csi2_ch3 (1 pad, 1 link)
 device node name /dev/video3
 pad0: Sink
 <- "csi2":7 []
- entity 34: rp1-cfe-fe_image0 (1 pad, 1 link)
 type Node subtype V4L flags 1
 device node name /dev/video4
 pad0: Sink
 <- "pisp-fe":2 []
- entity 38: rp1-cfe-fe_image1 (1 pad, 1 link)
 device node name /dev/video5
 pad0: Sink
 <- "pisp-fe":3 []
- entity 42: rp1-cfe-fe_stats (1 pad, 1 link)
 device node name /dev/video6
 pad0: Sink
 <- "pisp-fe":4 []
- entity 46: rp1-cfe-fe_config (1 pad, 1 link)
 device node name /dev/video7
 pad0: Source
 -> "pisp-fe":1 []
So, if I use another device from this list:
v4l2-ctl --list-ctrls -d /dev/v4l-subdev2
User Controls
 exposure 0x00980911 (int) : min=0 max=4341 step=1 default=1420 value=1800
 horizontal_flip 0x00980914 (bool) : default=0 value=0 flags=modify-layout
 vertical_flip 0x00980915 (bool) : default=0 value=0 flags=modify-layout
 temperature_in_celsius 0x00981920 (int) : min=-1024 max=1023 step=1 default=0 value=0 flags=read-only, volatile
 ae_light_level_target 0x00981921 (int) : min=0 max=100 step=1 default=30 value=30 flags=grabbed
 ae_convg_step_proportion 0x00981922 (int) : min=0 max=256 step=1 default=140 value=140 flags=grabbed
 ae_convg_leak_proportion 0x00981923 (int) : min=0 max=32768 step=1 default=11468 value=11468 flags=grabbed
 dark_calibration_pedestal 0x00981924 (int) : min=0 max=255 step=1 default=64 value=64
Camera Controls
 auto_exposure 0x009a0901 (menu) : min=0 max=1 default=0 value=1 (Manual Mode) flags=update
 auto_exposure_bias 0x009a0913 (intmenu): min=0 max=16 default=8 value=8 (0 0x0) flags=grabbed
 3a_lock 0x009a091b (bitmask): max=0x00000007 default=0x00000000 value=0 flags=grabbed
Image Source Controls
 vertical_blanking 0x009e0901 (int) : min=110 max=64175 step=1 default=808 value=3056
 horizontal_blanking 0x009e0902 (int) : min=116 max=116 step=1 default=116 value=116 flags=read-only
 analogue_gain 0x009e0903 (int) : min=0 max=28 step=1 default=0 value=0
Image Processing Controls
 link_frequency 0x009f0901 (intmenu): min=0 max=0 default=0 value=0 (402000000 0x17f60880) flags=read-only
 pixel_rate 0x009f0902 (int64) : min=160800000 max=160800000 step=1 default=160800000 value=160800000 flags=read-only
 test_pattern 0x009f0903 (menu) : min=0 max=7 default=0 value=0 (Disabled)
 digital_gain 0x009f0905 (int) : min=256 max=2048 step=1 default=256 value=256
Using this device, I can set the ioctls:
v4l2-ctl --set-ctrl auto_exposure=1 -d /dev/v4l-subdev2
v4l2-ctl --set-ctrl exposure=1800 -d /dev/v4l-subdev2
v4l2-ctl --set-ctrl vertical_blanking=3056 -d /dev/v4l-subdev2
Now, for the last command, I have tried every device from the media-ctl list:
v4l2-ctl --stream-mmap --stream-count=20 --stream-to=capture_20f.raw
 VIDIOC_STREAMON returned -1 (Invalid argument)
#I either get this or the other error
v4l2-ctl --stream-mmap --stream-count=20 --stream-to=capture_20f.raw -d /dev/video0
v4l2-ctl --stream-mmap --stream-count=20 --stream-to=capture_20f.raw -d /dev/v4l-subdev2
unsupported stream type
dmesg output after this exercise gets me:
[ 867.854751] rp1-cfe 1f00128000.csi: csi2_ch0 node link is not enabled.
[ 2675.872238] rp1-cfe 1f00128000.csi: csi2_ch0 node link is not enabled.
[ 2697.608510] rp1-cfe 1f00128000.csi: csi2_ch0 node link is not enabled.
[ 2717.221212] rp1-cfe 1f00128000.csi: embedded node link is not enabled.
[ 2718.689806] rp1-cfe 1f00128000.csi: csi2_ch2 node link is not enabled.
[ 2720.042199] rp1-cfe 1f00128000.csi: csi2_ch3 node link is not enabled.
[ 2721.258953] rp1-cfe 1f00128000.csi: fe_image0 node link is not enabled.
[ 2722.355612] rp1-cfe 1f00128000.csi: fe_image1 node link is not enabled.
[ 2724.313524] rp1-cfe 1f00128000.csi: fe_stats node link is not enabled.
Any ideas on what I need to do in order to make this work? Maybe enabling the link manually? I am not too versed on media-ctl, but I think it can be done through there, but ideally I would like a more permanent fix.
Dec 18, 2024 2:39 PM UTC
Hello invisiblepuzzle,
To stream with the a sensor on RPI5 you need to use libcamera stack you can find the Debian packages here:
- https://www.st.com/en/embedded-software/stsw-img503.html#get-software
To control the sensor you can still use V4L2
Dec 18, 2024 3:11 PM UTC
Thanks for the response.
With libcamera, will I still be able to use the hardware triggering, via GPIO1, or I2C sync? My main goal is to integrate the camera in a c++ codebase with this functionality.
Dec 18, 2024 3:13 PM UTC
libcamera is only for streaming for control please stay on V4L2-ctl
Dec 18, 2024 3:17 PM UTC
I still get the problem then whenever trying to get an image from v4l2, I get an error.
After talking also in the raspberry pi forums, I think there is a missing connection, not allowing me to take the images.
And in dmesg:
Do you know what could be the cause, or how I can fix that?
Dec 26, 2024 2:44 PM UTC
Hi ,
Seems other user have same issue i will check on my side and come back to you after
Merry Christmas
bye
Jan 19, 2025 4:14 PM UTC
I have encountered with the same problem!!! How can I solve it?!
Feb 3, 2025 4:20 PM UTC
Hello everyone ,
i'm back with a solution you need to control the subdev and you can only do it before the streaming of libcamera :
Identify your sensor’s V4L2 subdev file. Replace sensor with your sensor name:
ls /sys/bus/i2c/drivers/<sensor>/*/video4linux
With the previous command result as subdev_file, query the sensor V4L2 controls:
v4l2-ctl -d /dev/<subdev_file> --all
Set the chosen control to the wanted value:
v4l2-ctl -d /dev/<subdev_file> -c <control>=<value>
bye
