GMaid.2
It is expected the ALS (Ambient Light Sensor) VD6283 to have an overshoot in its initialization?
I'm performing some experiments with VD6283 breakout board in controlled conditions, and when it got first energized and initialized it presents an overshoot and a huge settling time (around 3 minutes) which is not reproduced in subsequent illuminance condition changes. Is this behavior expected for some particular reason? Or there is an way to overcome this situation?
BR,
Gabriel.
Douglas MILLER
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line. Should anyone have any similar questions, please feel free to open a Support case directly at your myST portal: https://st.com/ols
Anne BIGOT
This is not an expected behaviour. What is your initialization routine ?
The sensor should reply within less than a second.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
August 8, 2023
The initial overshoot and extended settling time you're experiencing during the first initialization can be influenced by various factors, including startup conditions and the device's internal processes.This behavior can sometimes be due to capacitive effects, power-up sequencing,  or calibration processes during the first initialization. It's not uncommon for certain sensors or components to exhibit variations during their initial power-up phase.
