That's because we changed the name on you. If you want the reflectivity, read the signal strength. But that's the signal strength the sensor sees. To find the reflectivity of an object at a given distance, I recommend reading the signal strength and number of SPADS. Then compute the signal per SPAD. Sometimes I nomalize it by multiplyiing by 200. (200 is pretty much the max number of SPADs you will see.) But that's up to you.
Using Signal per SPAD you get a good indication of what you are seeing.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
