How to achieve greater measurement precision close to Vl53L4CD?
- July 12, 2024
- 7 replies
- 5822 views
Greetings!
When I measure objects closer than 10 mm from the VL53L4CD, the result deviates significantly from what was expected, and the result also varies significantly depending on the texture and gloss of the object.
Is it possible to configure the VL53L4CD to be more accurate in the range 0 - 10mm distance from the sensor?
I have carried out some simple test measurements in the range 20 - 0 mm with the colors matt black, matt grey, light yellow and shiny white. Please read the uploaded PDF showing measuring test results and graphs.
Regards Jorgen
