Hanja_Frd
Nov 16, 2022 6:26 PM UTC
How do the time-of-flight sensors (eg VL6180, VL53L0X ...) technically work in detail?
I'd like to know how the tof sensors technically work in detail. I know about the principle (photons were sent and time taken until receiving the reflection), but how is the field of view created and how can some sensors have a lager FoV than others? What is the difference to a typical laser sensor?
John E KVAM
Nov 22, 2022 6:05 PM UTC
It all starts with the Vertical Cavity Surface Emitting Laser - VCSEL. The Field of View was simply a result of how they work. The Fiber optic market and the compact disk market for which they were built wanted a wide FoV. So it's a multi-stage VCSEL. A main beam lights up and very quickly after a outer ring lights up. ST adds a diffuser on top to smooth out the pattern of light. But the FoV is determined by the VCSEL physics.
(All the laser pointers in the world (and anything with a beam) use this same type of VCSEL, but they have a lens to focus the beam.)
The ST ToF sensors do NOT focus the beam. It's how we maintain our Class 1 optical safety.
The VL53L4 has a more narrow FoV because we use a single stage VCSEL that we designed.
The wider FoV of the VL53L5 and even wider VL53L7 is a result of a meticulously designed defusing optical element placed above the VCSEL emitter. These two sensors emit light in a prymid shape and not a cone. They are kind of amazing in that regard.
  • john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
