AWald.2
Feb 26, 2022 12:33 PM UTC
Hi all! When is the new VD55H1 sensor going to be released? Any date set?
John E KVAM
John E KVAMBest answer
Mar 8, 2022 3:26 PM UTC
It's going to be a long time between the announcement of silicon and an actual product that you might buy in a store. ST does the silicon, but counts on a module maker to convert that silicon into a module that has a lens, housing, control software and a ton of other things.
If you have a demand for a significant number of these, by all means contact ST and we can help you. But to make it pay it would take a LOT of units.
Eventually that silicon will make it into the market, but it probably won't have the ST name on it. And that's completely fine with ST.
Marketing suggests by Q2 2023 there should be something.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
