March 27, 2025
FDA accession number of the VL53L4CX
Do you have a FDA accession number for the VL53L4CX ToF chip? I can find only the document "VL53L4 IEC 60825-1 CB test certificate (eye safety)" at the attachments and there it isn't noted. Furthermore I guess it is not the same as for the VL53L5CX.
Regards Tobias
Anne BIGOT
Anne BIGOTBest answer
Hello
You are right the VL53L4CX FDA accession number if different from tje VL53L5CX.
In the case of the VL53L4CX it is : 2120927-000
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
Anne BIGOT
Hello
