DMeie.2
Oct 7, 2025 7:50 AM UTC
Difference between the VL53L7 CH and CX variants
What's the difference between the following sensor variants:
  • VL53L7CH
  • VL53L7CX
From what I've seen from going through the available product documents, they are all the same, performance-wise (range, frequency, FoV etc).
Difference between the CH and CX seems to only be the firmware with the CH being able to output histogram data?
Is this correct?
Can the CH still output the normal processed data?
Anne BIGOT
Anne BIGOTBest answer
Oct 7, 2025 12:50 PM UTC
Hello
Indeed, main difference is the firmware.
You can output compact and normalized histogram with te CH that you cannot with the CX.
The L7CH is also outputting processed data too.
Anne
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
Anne BIGOT
Hello
Anne
