can't get VL53l4CX board to work
i've been posting here a few times to get a VL53L4CX to work. I've had success so far, but the latest iteration of my little PCB is really giving me troubles.
When i apply power to my board (via an esp board) it stops working (the esp32 board). It feels like i've created a short, but i can't seem to measure that on the board.
I do solder this myself, so there could be a short under the sensor itself (i just use a heat gun from the bottom after tinning the pads). I've done this a few times now and i'm quite sure it's not the case... so there must be an issue with my board layout/design.
It would be great if somebody could review this for me?
http://cyclops.nettrends.nl/stuff/tofboard.tar.gz
cyclopsBest answer
And of course, after a night of sleep and another view: Pin 2 and 1 are connected. They are not supposed to be! Silly mistakes :(
cyclopsAuthorBest answer
John E KVAM
thanks for the update. You cannot believe how many people post a question, figure out the answer and never post the solution. Nice job. :)
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
