May 13, 2025
Any cable that works to connect P-Board (STEVAL-CAM-M0I) to Raspberry Pi 1/2/3/4?
I wish to connect the P-board, which has a 22-pin connector, to a Raspberry Pi that has a 15-pin camera connector (From the Raspberry Pi 1/2/3/4 series, not the 5). The datasheet for the P-board only gives a vague suggestion. Is there a specific cable that has been known to work?
mikequekBest answer
Hi JohannH,
You can use a standard to mini FPC from this link
mikequekBest answer
Hi JohannH,
