LCHAN.41
About overcome indirect sunlight problem with vl6180X/V1?
Hey,
I am using a customize board (MCU:STM32L452CCU6) to develop a gate checker with vl6180/V1 and cover glass with IR filter. Implemented a default value and setting ,the sensor and code works fine indoor. But in the outdoor condition under the sunlight, the sensor only shows 255. I read the datasheet, some setting could help me to overcome this situation, but I don't know which steps should i go first( crosstalk,threshold , convergence time or SNR?). So, which parameter should i deal with it first in order to solve this problem?
Anne BIGOT
Anne BIGOTBest answer
You can find some advices in this community.
In the following post for example, here.
Anne
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
Anne BIGOT
Anne
