ngodoanvan
Dec 4, 2023 8:47 AM UTC
TESEO VIC3DA
How to know the TESEO VIC3DA module work correctly in designed board ?
Thank you very much
Dec 6, 2023 9:43 AM UTC
Hi
1. You should have NMEA stream on the UART
2. in the $xxGSV you should have consistent data (to check RF-path)
3. the board should be strongly fixed to the car
4. after 10 minutes driving (time to calibrate) your VIC will be fully calibrated
Hi
ngodoanvan
Dec 6, 2023 9:49 AM UTC
thank you very much
