Feb 6, 2024 7:24 PM UTC
Teseo-LIV4F fix rate slower than it should be
I am working with a LIV4F, and I am trying to configure the fix rate at 10hz like so:
$PSTMSETPAR,1130,0x00,0
$PSTMSETPAR,1303,0.1,0
$PSTMSAVEPAR
$PSTMSRR
The LIV4F responds with:
$$PSTMSETPAROK,1130*30
$$PSTMSETPAROK,1303*32
$$PSTMSAVEPAROK*5C
All appears to be good. However, when analyzing the data, the update rate is much slower than 10hz, fluctuating between 3.5hz and 5hz. I can turn down the fix rate, and I get the expected results, but anything above 5hz does not work as expected.
Mar 6, 2024 8:41 PM UTC
Could you please let me know what firmware version you are using?
Also can you try to send the command,
$PSTMSAVEPAR
$PSTMSRR
Please ensure your baud-rate is also set sufficiently high, 115200 minimum. Higher the better. Check CDB-102 for this.
$PSTMSETPAR,1102,0xC
$PSTMSAVEPAR
$PSTMSRR
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
