AAl S.1
Mar 26, 2020 3:46 PM UTC
TESEO-LIV3F
Hi, I have TESEO-LIV3F , I want to power the GPS when it's needed. I have backup battery connect to VBAT because i want to have hot start .
1- In my case how much current draw from the GPS when only VBAT powered? It says in data sheet 6uA as hardware standby, Is it the case when I just power VBAT?
2- what is the difference between hardware standby and software standby? and why software standby current is 12uA?
    Mar 31, 2020 6:02 AM UTC
    Hi
    >  Is that correct?
    Yes. it's correct.
    Francesco
    Mar 26, 2020 4:01 PM UTC
    Hi
    Yes. this is exactly the HW Standby
    In case lo SW-Standby VCC and VCC_IO remain applied. This is the case when GNSS-firmware drivers the low power enter/exit procedure (i.e.: Periodic Standby or when you trigger the commands PSTMFORCESTANDBY)
    Hope this helps
    Francesco
    AAl S.1
    AAl S.1Author
    Mar 26, 2020 4:15 PM UTC
    Thank you fro your answer just to make it clear and correct me please if i am wrong. while VCC and VCC_IO is off and backup battery is connect to VBAT, The current will be 6uA and I will get hot start when I power the GPS again. Is that correct?
    Hi
    >  Is that correct?
    Yes. it's correct.
    Francesco
