Nov 7, 2024 10:21 AM UTC
STA8100 NMEA Data Flow Filter
Currently using the STA8100_MF_DRAW_Binary_Image_v5_9_22 firmware, could you demonstrate commands to specify the received NMEA data streams, such as $GPGSV, or commands to disable all data streams & control the output frequency? It would be great if there is any GitHub initialization code available.
Thank you.
GalaxyQuestBest answer
Nov 21, 2024 9:59 PM UTC
To access STA8100 firmware configuration, please reach out ST Sales and Marketing. The documents specifying the bit fields to set are not intended for mass market.
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Nov 7, 2024 11:39 AM UTC
Check firmware docs for $PSTM configuration methods, or Teseo Suite for command code templates/output forms.
I'll lock at docs when at a computer.
