DTali
Jun 3, 2019 2:53 PM UTC
SatID meaning
Hello. I received message:
$PSTMTS,1,71,124558707.19,-52058.20,01,31,6410,1,21868253.91,-7485903.62,10859223.75,1461.22,-315.33,-3150.47,-13521.55,13.38,0,0.00,0.00,0,0,0,0*14
where 71 is satID. i need to know is it GPS or GLONASS to determine carrier frequency. how can i do that?
    Jun 3, 2019 3:15 PM UTC
    Teseo Satellite ID https://www.st.com/content/ccc/resource/technical/document/user_manual/group0/5b/f7/86/c6/95/c7/49/20/DM00398983/files/DM00398983.pdf/jcr:content/translations/en.DM00398983.pdf
    It can be configured two ways, as I recall.
    The normal way to convert to a GLONASS satellite is to subtract 64. GPS satellites would report as 1 thru 32. GLONASS as 65 thru 88
    I'm sure one could easily confirm/verify using Teseo Suite..
    Jun 4, 2019 8:01 AM UTC
    From Teseo-3 Binary Image User Manual:0690X000008iASVQA2.png
    Hope this helps
    Francesco
    DTali
    DTaliAuthor
    Jun 5, 2019 8:47 AM UTC
    there are 24 GLONASS satellits now, but 99-64 = 27.
    I received satNum=91. is it GLONASS?
    Jun 5, 2019 9:02 AM UTC
    Hi
    if Sat-ID is in the range [65 - 92 ] then it's a GLONASS satellite
    Francesco
    DTali
    DTaliAuthor
    Jun 5, 2019 9:34 AM UTC
    look at this table:
    https://www.glonass-iac.ru/en/GLONASS/ephemeris.php
    there are only 1 to 24 satellites in GLONASS, if i received satID=91. 91-64=27
    where can i find Number of Frequency Slug for satellite 27?
