Mar 6, 2025 6:39 PM UTC
Programming STA8135GA (TESEO V)
Is it possible to write our own firmware for STA8135GA IC? I want to get the raw measurements from the baseband IC in STA8135GA and implement my own navigation algorithm and load the firmware to the IC. Is this possible?
GalaxyQuestBest answer
Mar 8, 2025 1:31 PM UTC
For ICs like Teseo-5 we provide PVT generally (you cannot load your navigation solution) but we provide code and carrier phase measurements. Therefore, if you want to implement an RTK algorithm for precise positioning, this is possible.
If you want to implement RTK engine running on a host MPU, you can check out our LIV4F module. LIV4F module also outputs code and carrier phase as MSM7 messages like Teseo-5
Regarding Teseo-5 navigation algorithm, could you please private message me your project details?
Industry/Education/Research?
Volume?
Location?
Thanks,
George
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Volume?
Location?
Thanks,
George
enemraAuthor
Mar 8, 2025 2:53 PM UTC
Thank you for the info. I have sent you a message.
