Aug 23, 2023 5:33 PM UTC
PPS output from Teseo-LIV3R
What is the timing specification of the PPS (Pulse Per Second) output from the Teseo-LIV3R in terms of pulse width and/or duty cycle?  I've reviewed the datasheet, UM2523 (ST Teseo III ROM binary image - User manual), and UM2231 (Teseo-LIV3 GNSS Modules - Hardware Manual) but don't see this specified.
Aug 23, 2023 6:05 PM UTC
There are parameters and settings you can read out.
For the docs looks to be 1 Hz 50/50 duty, quantization probably +/-16ns
hjsteger0Author
Sep 12, 2023 6:00 PM UTC
Hi Tesla DeLorean,
I'm not sure if you saw my question from last week.  You wrote "For the docs looks to be 1 Hz 50/50 duty, quantization probably +/-16ns" but I can't find the document that specifies this.  Would you please tell me where you found this specification?
Sincerely,
Hal
hjsteger0Author
Sep 5, 2023 8:51 PM UTC
Hi Tesla DeLorean,
Thanks for the replying to my question.  In which document did you find this information?
Jan 8, 2025 3:53 PM UTC
Additional question, is it the rising edge or the falling edge that is synchronized to the second rollover?
Jan 15, 2025 4:36 PM UTC
For timing applications, I would consider using Teseo LIV3FL.
You can adjust the pulse duration (time from rising to falling edge) of the PPS signal by changing CDB-301.
Datasheet https://www.st.com/resource/en/datasheet/teseo-liv3fl.pdf
You can find the link to Software manual here.
https://www.st.com/resource/en/user_manual/um2229-teseoliv3-gnss-module--software-manual-stmicroelectronics.pdf
LIV3FL has same pinout of LIV3R but LIV3FL can do 3 constellations and is a flash based device.
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
