EGola.1
Mar 17, 2024 10:20 AM UTC
Liv4F operating voltage range - Documentation inconsistent
Liv4F module.
Operating voltage range in the data sheet stated 3v-3.3v
In the Manual 1.8v-3.3v  what is true?
Can you fix the documents???
STOne-32
Mar 17, 2024 10:27 AM UTC
Hi @EGola.1 ,
Thank you for the valuable remark :
https://www.st.com/resource/en/user_manual/um3004-teseoliv4f-and-teseoliv4fm-hardware-documentation-stmicroelectronics.pdf
on our TESEO LIV4F module .
have a great Sunday
STOne-32
EGola.1
EGola.1Author
Mar 17, 2024 2:17 PM UTC
So, 1-8v-3.3v?
Correct?
Apr 4, 2024 12:27 PM UTC
LIV4F can operate only at 3.3V.
We are fixing the documentation and releasing it this quarter.
Thanks for your patience.
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Mar 3, 2026 8:53 AM UTC
so now we have also conflicting statements from ST employees here: STOne-32 points to UM3004 (stating 1.8V to 3.3V, can be left floating) and GalaxyQuest writes "only 3.3V" which is not even the spec from the data sheet (3V too 3.63V).
Is there any chance of a final statement? And fixed documentation?
Mar 3, 2026 1:26 PM UTC
For operating conditions like voltage, the datasheet takes precedence, therefore 3V - 3.63V. LIV4F cannot operate down to 1.8V. The hardware manual, UM3004 is mainly for pin guidelines.
Hope this helps.
STOne-32
Mar 3, 2026 2:34 PM UTC
Thank you @GalaxyQuest  confirming the statement . Much appreciated
Dear @bofh ,
Hope now it is more clear .
have a great day
STOne-32
