Gero
May 22, 2019 12:15 PM UTC
How to use the NVM API of the TESEO III ?
I'm working with the TESEO III (STA8090). I want to save data on the NVM of the chip. Using the gps_nvm API by ST, I call the nvm_open() function and next the nvm_mount() nvm_create() function to creat a memory slot. The function returns success but the debugging log shows that it failed to create the item. Moreover the nvm_write function fails to write the slot.
Following the documentation, I use the slot ids allowed to the user.
Have you face this problem before ? Do you have any advice or example to acheive writing and reading the NVM ?
    May 23, 2019 12:38 PM UTC
    Hi
    Sorry but ST doesn't have an nvm_mount()  API.
    Which documentation/code are you referring?
    Francesco
    Gero
    GeroAuthor
    Jun 11, 2019 11:10 AM UTC
    Sorry it was a mistake, I not using the nvm_mount() but the nvm_create() function.
    I'm referring to the documentation "Automotive Product Group - NVM spcification"
    Best
