Dror
Nov 24, 2019 1:17 PM UTC
GNSS Jamming detection
Does TeseoIII have any programmable or any other indication to provide GNSS Jamming detection?
    Nov 25, 2019 8:14 AM UTC
    Hi Dror
    You can have a look @ https://www.st.com/resource/en/product_presentation/presentation_teseo_3_security_mm.pdf
    Hope this helps
    Francesco
    Dror
    DrorAuthor
    Nov 27, 2019 2:54 PM UTC
    Hi Francesco,
    The referenced document above is referring to GNSS modules with regards to GNSS Jamming detection (3-bit ADC converter, AGC and ANF).
    What extra hardware does the GNSS module have internally which is different than using only the TESEOIII IC as a solution for Jamming detection?
    Nov 27, 2019 2:58 PM UTC
    Hi Dror
    Sorry but the document is addressing both TeseoIII chip and Teseo Module because all the Anti-Jamming capability are inside to the chip or the firmware.... not related to special component on the module.
    Hope this helps
    Francesco
