May 10, 2024 9:13 PM UTC
EVB-LIV4F USB linux driver
I would like to know if EVB-LIV4F has USB linux driver. I would like to connect EVB-LIV4F to a ubuntu computer.
Thanks,
Koon
May 23, 2024 2:14 PM UTC
Hi Koon,
Are you asking if we have Teseo Suite installation on Linux?
Currently Teseo Suite install is only for Windows.
If it is CUBE-GNSS software for development on an MPU, we have https://www.st.com/en/embedded-software/x-linux-gnss1.html. This is currently implemented for LIV3x module, however LIV4F commands are compatible.
Also please note that LIV4F uses NMEA 4.1, so there might be tweaks that are necessary in NMEA data that is received.
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
