MPete.5
May 13, 2021 8:33 PM UTC
Cannot enable the autonomous STAGPS engine on TESEO-LIV3R
I have a Teseo LIV3R on a breakout board connected (via UART) to Tesio Suite. I'm trying to figure out how to enable STAGPS and test its functionality. Unfortunately I cannot enable the autonomous STAGPS engine using the command:
$PSTMSTAGPSONOFF,1
When sending the command $PSTMSTAGPSONOFF,1 to the module, I get no response. I would expect a response such as $PSTMPOLSTARTED. When sending the command $PSTMCFGAGPS,1 I get a response that the AGPS engine has been enabled. I would like to enable the autonomous STAGPS functionality though but I am not able to.
Hopefully someone canhelp or have an idea what the problem is?
Also, I was not able to confirm if the autonomous STAGPS function is enabled as default. Does anyone know if it is, and how to confirm this?
Thanks in advance.
    May 14, 2021 3:01 PM UTC
    Hi
    ST-AGPS is enabled by default in LIV3R.
    Francesco
    MPete.5
    MPete.5Author
    May 18, 2021 11:46 AM UTC
    Thanks Francesco, do you know how I can verify that as well as switch on/off this feature?
    I had no luck using $PSTMSTAGPSONOFF,1 and $PSTMSTAGPSONOFF,0
    Thanks,
    Martin.
