waclawek.jan
Jun 24, 2023 7:29 AM UTC
Why the spinning circle at the bottom of notification feed?
It just turns infinitely. Why?
    waclawek.jan
    Jun 27, 2023 9:06 AM UTC
    Hi @Lina_DABASINSKAITE  ,
    > the list expands, and the spinning circle disappears as well
    I tried, and at the first attempt, the list expended by exactly one post, the "Show more" disappeared and spinning circle remained... retried, with the same result. Then I decided to retry once more while taking screenshots, but then the behaviour changed, the list expanded by a whole bunch of items, and both "Show more" and spinning circle appeared again. They disappear only upon repeated presses when I get to the very bottom of the list.
    Lina_DABASINSKAITE
    ST Community Manager
    Jul 5, 2023 10:10 AM UTC
    Hello @waclawek.jan ,
    I cannot reproduce this issue anymore. On which browser does this happen to you? This could be considered as a performance issue, and we need to check the exact browser.
    BR,
    Lina
    ​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
    Lina_DABASINSKAITE
    Jul 6, 2023 8:59 AM UTC
    Legacy message: ‎2023-07-05 03:17 AM
    Thanks for brining that up. When you press "Show more", the list expands, and the spinning circle disappears as well. I am looking into it, weather it is an expected UI/UX behavior or a glitch.
    Thanks,
    Lina
