Aug 12, 2026 4:00 PM UTC
"Send" button grayed out while editing a post
I was trying to edit my post here:
https://community.st.com/feedback-forum-118/inconsistent-presentation-of-links-167657?postid=747370#post747370
After inserting images and links and stuff, the “Send” button was grayed out. I had to hit “Cancel”, edit the post again, redo everything, and hit send (which was not grayed out this time). No indication as to why it was grayed out.
Andrew Neil
Aug 12, 2026 4:54 PM UTC
I have also seen this happen
Zita LASZLOFI
ST Community Manager
Aug 14, 2026 4:15 PM UTC
Hi both ​@TDK and ​@Andrew Neil
Thank you for flagging this. I reached out to our platform provider. I will keep you informed on this thread.
Kind Regards,
Zita
Zita LASZLOFI
Aug 20, 2026 5:09 PM UTC
Hi both. Thank you for your patience.
We found that it usually happens while the text editor is still loading, in this case it is probably related to the image uploads. For further investigation we would need more samples, so please let us know if you experience this again.
Kind Regards,
Zita
TDKAuthor
Sep 22, 2026 3:09 AM UTC
Andrew Neil
Oct 12, 2026 11:35 AM UTC
Have just had this happen again to me:
The inserted pictures were all showing fine in the editor.
I had to copy & paste into a new editor to make the post:
I also had a couple of these:
Looks like there’s a performance issue on the server, and it does not fail gracefully.
See also:
Andrew Neil
Oct 12, 2026 11:58 AM UTC
Just happened again - this time in a reply:
In this case, the ‘Send’ button has its disabled, light-yellow colour - it doesn’t go grey when disabled.
It should look like this:
Again, I had to abandon the reply, and start again from scratch:
PS:
If I try to leave the web page - without pressing ‘Cancel’ - I do get the warning:
Andrew Neil
Oct 14, 2026 8:29 AM UTC
and again just now:
Andrew Neil
Nov 6, 2026 10:13 AM UTC
Happened again just now:
Andrew Neil
Nov 6, 2026 10:22 AM UTC
I just watched what happens when you paste an image into a post: the ‘Send’ button does get disabled briefly until the image appears.
So it seems that there is an issue somewhere which sometimes stops the button getting re-enabled
