David Littell
Senior II
Jan 31, 2026 3:09 PM UTC
Safari sensitivity for deleting and editing posts?
Using Safari 26.2 I'm unable to delete or edit my own posts.  Does anyone else
Jan 31, 2026 3:51 PM UTC
You should be able to edit with the down arrow in the top right of your post or reply. No problems here doing this with Safari.
You cannot delete posts. You can flag them as “inappropriate content” and use the note to request a moderator delete them if you want. Usually editing is sufficient.
Edit: test.
David Littell
Senior II
Jan 31, 2026 6:05 PM UTC
Thanks, but that doesn't work for me.  Odd.  What happens after you select "Edit Message"?
Lina_DABASINSKAITE
ST Community Manager
Feb 2, 2026 8:19 AM UTC
Hi @David Littell,
Thie should work for you on all browsers the same. You have to be logged in for this action. Once you hit Edit message, you should see the text editor window:
Please see if you experience a different behavior on different browsers and let me know.
Regards,
Lina
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
