waclawek.jan
Jul 28, 2023 1:44 PM UTC
Notification missing from the notifications list
I've clicked on the "bell icon" *after* I've seen this "new notification" on the frontpage.
I've even force-reloaded the notification feed page, but it did not change.
No big loss, just another example that Khoros is just another overjavascripted crap.
    waclawek.jan
    Jul 28, 2023 2:28 PM UTC
    ... and yes, it *did* appear in the list later, but I did not check, when.
    Aug 7, 2023 6:37 AM UTC
    Hi @waclawek.jan
    Thanks for reporting this. Could you please confirm if it was only one-time thing or you see it constantly with all notifications? I've tried to test on my side but usually the notifications are displayed correctly in the feed.
    Michael
    waclawek.jan
    Aug 8, 2023 6:18 AM UTC
    Hi Michael,
    No, I don't make a deliberate observation like this regularly, nor do I intend to watch actively for occurence of this.
    This is obviously consequence of unnecessarily complicated design which ultimately will lead to the same modes of failure than jive and salesforce did. It was your choice, without listening to users, again.
    Aug 13, 2023 7:39 PM UTC
    Hi @waclawek.jan
    Please let us know if you notice a similar issue with any other notification and we'll try to investigate further. Unfortunately for now we are not able to reproduce this issue.
    Michael
    Oct 26, 2023 10:30 AM UTC
    Hi @waclawek.jan ,
    Thank you for your patience and sharing your feedback. Can you tell us what browser and system you use most often when you notice such cases? This will allow us to better target our internal testing.
    Best,
    Adam
    waclawek.jan
    Oct 26, 2023 10:52 AM UTC
    Hi Adam,
    Most often?
    I've noticed this once. It would be silly to expect me to check for such irregularity regularly, wouldn't it.
    I usually use FF on Windows, it might've been Win8.0 or some flavour of Win10.
    @unknown
    waclawek.jan
    Sep 9, 2025 9:05 AM UTC
    OK so I've just noticed the same thing happening.
    waclawek.jan
    Sep 9, 2025 9:39 AM UTC
    It did appear eventually in the list, but later than I made that post above (I *did* reload that list *after* I made the post at 11:05, just to be sure).
    I've noticed it only when the next item arrived into it, at 11:39, did not look at it meantime.
    Andrew Neil
    Sep 9, 2025 10:15 AM UTC
    Not sure if this is quite the same:
    On the left (the main forum front page), it says it's a "Reply"; on the right (the notifications feed), there is a "Moved" notification - but no "Reply"
    PS:
    If I look in the thread, there is no reply from @Maxime_MARCHETTO
    Lina_DABASINSKAITE
    ST Community Manager
    Sep 15, 2025 8:33 AM UTC
    Hello @Andrew Neil,
    Thanks for sharing this. Passed to the respected team to double check if this is an expected output in different components.
    If you notice anything else, let me know.
    Thanks,
    Lina
    ​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
    waclawek.jan
    Sep 9, 2025 10:47 AM UTC
    IMO different (and maybe two issues in one - incorrect wording plus leaking something which should have remained hidden to us), but similarly confusing.
