Andrew Neil
Jul 9, 2026 9:18 AM UTC
Need a way to post "preformatted" text which is not code
For example, a table like this:
This has been posted using the code editor, so it has inappropriate C syntax highlighting.
On the old forum, there was a ‘Preformatted’ option in the paragraph formats menu:
The ‘Code’ option in the new forum is not equivalent:
It’s a character format - not a paragraph format.
It doesn’t work for blocks of text (such as the table example above) - it’s for highlighting individual keywords within a paragraph.
I made a post about this for the old forum in the How to write your question to maximize your chances to find a solution article (note that the new forum has mangled the examples in that post).
We need an equivalent for the new forum
Perhaps a ‘Plain Text’ option in the code editor?
Andrew Neil
Jul 9, 2026 1:47 PM UTC
This forum doesn’t even have the option to use a mono-spaced (fixed-width) font.
Andrew Neil
Jul 14, 2026 1:24 PM UTC
Hmmm … it looks like the ‘Markdown’ language option in the Code editor might be usable:
| a | a directed line | another |
| box | | box |
Andrew Neil
Jul 14, 2026 1:27 PM UTC
This is how it appeared in the post editor:
But what we actually get is this:
I guess it’s better than nothing - but still not great.
And still WYSINWYG - What You See Is Not What You Get !
unsigned_char_array
Lead III
Jul 15, 2026 8:17 AM UTC
In some markdown flavors you can add a code block. Let me test it:
Editing before inserting:
Preview after it was inserted:
Result:
| box | | box |
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
