Andrew Neil
Jun 30, 2026 2:02 PM UTC
Inconsistent code background
Here:
In the ‘Best Answer’ shown at the top of the thread (immediately after the OP), it’s on a black background:
But, in its original position within the thread view, it’s on a grey background:
Note also that the line spacing is different - so the “ASCII Art” no longer works properly
Lina_DABASINSKAITE
ST Community Manager
Jul 3, 2026 7:15 AM UTC
Hello all,
the issue has been fixed, and code background are now consistent.
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
unsigned_char_array
Lead III
Jun 30, 2026 2:07 PM UTC
the link doesn’t work properly
If I click it it goes to this topic:
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
mƎALLEm
Jun 30, 2026 4:26 PM UTC
Same issue reported here:
Andrew Neil
Jun 30, 2026 5:00 PM UTC
​@mƎALLEm ​@unsigned_char_array - at least it manages to find a thread with “Background” in the title!
Try this:
https://community.st.com/stm32cubemx%2Dmcus%2D29/how%2Dto%2Dorganize%2Dthe%2Dfolder%2Dstructure%2Din%2Dcubemx%2Dgenerated%2Dcode%2D162030
Again, I have just taken the ?postid=162030#post162030 off the end of the URL.
So it seems to be something to do with getting that suffix part of the URL wrong.
Somebody else somewhere earlier today mentioned that maybe the new forum isn’t coping well in cases when the thread title got changed on the old forum - which didn’t necessarily always get updated everywhere...
Lina_DABASINSKAITE
Jul 1, 2026 3:11 PM UTC
Hello ​@Andrew Neil,
Thanks for catching this! I have asked our vendor to adjust the style of code blocks. Will let you know once that’s done.
P.s. URL redirect topics has been also raised and I will provide updates here: 'Copy Link' menu option gives wrong link. | Community
Regards,
Lina
Lina_DABASINSKAITE
Hello all,
