Code block wrapping makes it impossible to see long lines
If a “word” in a code block is longer than the wrapping distance, it is impossible to see the rest of the line. Here, it is impossible to see what is beyond the “…/CMSIS/Dev” in the path.
Since long path names are often included in code blocks, this occasionally happens.
Proposed solution:
Wrapping should be disabled in code blocks
or
A scroll bar should exist to be able to see the rest of the line when something like this happens.
(Apparently wrapping in code blocks is “working as intended” even though it seems like the consensus from the community is that it is not the desired behavior. Fine. This is a separate issue as a result.)
Line wrapping in code blocks | Community
