waclawek.jan
Can't see breadcrumbs on main ST web
There's no forum to report bugs on main st.com site.
Breadcrumbs appear briefly when scrolling, but then they are overlapped by the "stuff" on top.
The "modern" webdesign is a disaster.
    Lina_DABASINSKAITE
    ST Community Manager
    April 5, 2024
    Hello @waclawek.jan ,
    Can you please check now? I got informed and the issue has been resolved.
    Thanks,
    Lina
    ​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
    Lina_DABASINSKAITE
    January 10, 2024
    Hi @waclawek.jan ,
    Thanks for bringing this is up. This seems not a bug but a design solution - the breadcrumbs are not fixed on top when scrolling.
    AScha.3
    Hey, @waclawek.jan ,
    now you know :
    waclawek.jan
    Hi @Lina_DABASINSKAITE ,
    You seem to have misunderstood me.
    The breadcrumbs are *not* visible in the static case, that's how I made the above screenshot.
    They are visible only briefly during scrolling, and when scrolling stops, the top stuff overlaps them.
    Lina_DABASINSKAITE
    January 12, 2024
    Hi @waclawek.jan ,
    I see, thanks for clarifying. Please share the browsers and its' version you use so we can investigate.
    I checked myself on Chrome, Firefox, Edge - was everything fine.
    Thanks,
    Lina
    waclawek.jan
    Lina_DABASINSKAITE
    January 15, 2024
    Thanks, @waclawek.jan!
    I will pass it to a responsible team to further look into it.
    Could you also try opening it on other browsers and see if the issue replicates on your end?
    Thanks,
    Lina
    waclawek.jan
    I don't use other browser on PC.
    waclawek.jan
    This is a laptop with HD (1920x1080) display, but its physical dimensions are too small, so I use the 125% zoom (which btw. is the default and "recommended" by Windows itself):
    As an experiment, I've set it to 100% and the breadcrumbs became not been overlapped; but that's not a practically usable setup for this hardware, of course.
    I hope this helps to find the bug.
    Lina_DABASINSKAITE
    January 17, 2024
    Hello, @waclawek.jan ,
    Our team got back and found out exactly the same - the breadcrumbs position changes when screen scale is more than 100%. They are working on the fix.
    Thanks a lot for your inputs here.
    BR,
    Lina
    Lina_DABASINSKAITE
    March 7, 2024
    Hi @waclawek.jan ,
    The fix has been implemented. Please check if it is OK on you end too.
    Thanks,
    Lina
    waclawek.jan
    No, it's not OK:
    This is after clearing all site data and cache.
    W10, FF123.0.
    Lina_DABASINSKAITE
    April 5, 2024
    Thanks,
    Lina
    waclawek.jan
    It appears to work now, at least on the laptop where I noticed it initially.
    Thanks,
