Andrew Neil
Jul 31, 2026 8:35 AM UTC
'Best Answer' is misleading - should be 'Solution'
On the old forum, we had ‘Mark As Solution’
This is good: people come to the forum looking for solutions - so it is important to mark when a solution is found.
The current forum calls this ‘Best Answer’ instead.
This is bad: the best answer  does not necessarily solve the problem!
It is misleading and does confuse new members - see:
Andrew Neil
Nov 4, 2026 11:14 AM UTC
The forum itself backs this up:
A solution is what people are looking for !
AScha.3
Nov 4, 2026 5:19 PM UTC
 But  I always get the feeling: “solution” or “best answer” ...also tend to present the final resolution of any problem—which, in most cases, can only be carried out by the user themselves—as *the* solution. However, what should actually be highlighted here is the crucial piece of advice that leads to the solution. Not the final: “now i did it and it works now.”
Therefore, my suggestion would be to mark the "answer that leads to the solution" instead .
@mƎALLEm ​@AScha.3 there’s really 2 separate issues here:
  1. Identifying the solution to the issue(and, thus, that the issue is solved).
  2. Crediting those who contributed to the solution.
I think this should be split-off to a separate discussion (in feedback).
So here we are.
And “Identifying the solution to the issue” is almost useless, see:
> my nucleo cannot connect...<
# try other plug, try new cable, check: is it charger cable ?
> i did, now it works. <   = this is the solution.
But this is no useful help for anybody else, as he has to search the info: what was the way to get to the solution.
So i still think, the best indication, what to do or read, is to be marked. Not the “I did it, and it works now.” .
Andrew Neil
Nov 4, 2026 5:53 PM UTC
 > i did, now it works. <   = this is the solution.
No, it is not.
That’s just confirming that the issue was solved; the post which said how to solve it is the one which should be marked as The Solution.
AScha.3
Nov 4, 2026 6:09 PM UTC
Right, but many users see it this way. They did the solution. And basically they are right - right ?
I had many of these kind…
Thats why i think: mark just “solution” is not the best idea.
