1st time in the forum. Hello to all !
Hello Everyone, My name is Konstantinos and it is my very first post in this community so please forgive possible mistakes. Im posting here since i failed to find any "introduction" topics.
I work as PCB repair electronics technician and when it comes to programming i have only moderate knowledge of C language and little experience on programming MCU's. I started with arduinos and hope to get to learn stm32 mcu's. As you probably figured i have 0 experience with stm32 and i would like some guidance on where and how to start. Any advice appreciated.
Thank you all !
    Andrew Neil
    Andrew NeilBest answer
    Welcome to the community.
    On the home page - https://community.st.com/  - you will see some 'Getting Started' tips:
    ST have a YouTube channel - lots of training videos there: https://www.youtube.com/@stmicroelectronics
    Those from the 'Support & Community' and 'STM32 Developer Zone' links on the main ST Home page:
    mƎALLEm
    Hello and welcome to STM32 world.
    You can start by this Wiki.
    Andrew Neil
    HellasTAuthor
    Thank you all for your suggestions. I will check them out all one by one.
    Wise is not he who knows many. Wise is he who knows useful. Aeschylus.
    unsigned_char_array
    Lead III
    April 24, 2024
    Welcome!
    A few more tips:
    There is a great YouTube channel with many STM32 examples called ControllersTech. Those videos helped me out quite a lot.
    Learning embedded programming is a very steep learning curve. But don't give up. Try lots of little experiments by making a lot of small programs where you try out 1 new thing. Always make backups or use software versioning such as git so you can always go back to an older working version of a project if it suddenly stopped working (one line of code can cause issues or a project file can get corrupted).
    "Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
    HellasTAuthor
    Thank you  uint8_t [] :) .  That was really good advice !
