Dec 11, 2024 10:09 AM UTC
X-Cube-AI: There is an issue to initiate when run my deployed CNN on STM32F767
Dear Sir/Madam,
I have a trained CNN model converted to .TFlite file. The file has been analysed and validated on PC and Target. All are correct. Then an application template was developed. When I tried to run initiate CNN model with generated function " static int ai_boostrap(ai_handle *act_addr)", there is issue in this layer:
ai_bool cnn1_configure_activations(ai_network* net_ctx, constai_network_params* params) (Can not go deep anymore).  Always return false.  From ai_cnn1_init() returned an error type 48 and error code 19 as shown in the screenshot attached.
Would you please help me sorting out this issue?
QS
Appendix:
AI_DECLARE_STATIC
ai_network* net_ctx, const ai_network_params* params)
AI_ASSERT(net_ctx)
if (ai_platform_get_activations_map(g_cnn1_activations_map, 1, params)) {
/* Updating activations (byte) offsets */
serving_default_Combined_Input0_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 632);
serving_default_Combined_Input0_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 632);
slice_38_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 992);
slice_38_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 992);
slice_51_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1112);
slice_51_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1112);
conv2d_99_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1152);
conv2d_99_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1152);
nl_99_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1152);
nl_99_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1152);
pool_102_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1152);
pool_102_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1152);
slice_45_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1112);
slice_45_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1112);
conv2d_82_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1344);
conv2d_82_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1344);
nl_82_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1344);
nl_82_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1344);
pool_85_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1344);
pool_85_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1344);
slice_39_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1112);
slice_39_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1112);
conv2d_67_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1536);
conv2d_67_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1536);
nl_67_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1536);
nl_67_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1536);
pool_70_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1536);
pool_70_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1536);
concat_104_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1728);
concat_104_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1728);
slice_19_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 992);
slice_19_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 992);
slice_32_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1112);
slice_32_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1112);
conv2d_93_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2304);
conv2d_93_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2304);
nl_93_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2304);
nl_93_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2304);
pool_96_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1112);
pool_96_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1112);
slice_26_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1304);
slice_26_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1304);
conv2d_77_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2304);
conv2d_77_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2304);
nl_77_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2304);
nl_77_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2304);
pool_80_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1304);
pool_80_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1304);
slice_20_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1496);
slice_20_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1496);
conv2d_62_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2304);
conv2d_62_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2304);
nl_62_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2304);
nl_62_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2304);
pool_65_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1496);
pool_65_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1496);
concat_98_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2304);
concat_98_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2304);
slice_0_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 992);
slice_0_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 992);
slice_13_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 632);
slice_13_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 632);
conv2d_87_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2880);
conv2d_87_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2880);
nl_87_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2880);
nl_87_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2880);
pool_90_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 632);
pool_90_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 632);
slice_7_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 824);
slice_7_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 824);
conv2d_72_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2880);
conv2d_72_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2880);
nl_72_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2880);
nl_72_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2880);
pool_75_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1112);
pool_75_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1112);
slice_1_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 824);
slice_1_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 824);
conv2d_57_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2880);
conv2d_57_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2880);
nl_57_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2880);
nl_57_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2880);
pool_60_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 824);
pool_60_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 824);
concat_92_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 2880);
concat_92_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 2880);
concat_105_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 0);
concat_105_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 0);
conv2d_107_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 1728);
conv2d_107_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 1728);
nl_107_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 0);
nl_107_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 0);
gemm_117_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 192);
gemm_117_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 192);
nl_119_nl_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 576);
nl_119_nl_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 576);
gemm_121_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 0);
gemm_121_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 0);
normalization_122_output_array.data = AI_PTR(g_cnn1_activations_map[0] + 16);
normalization_122_output_array.data_start = AI_PTR(g_cnn1_activations_map[0] + 16);
return true;
AI_ERROR_TRAP(net_ctx, INIT_FAILED, NETWORK_ACTIVATIONS);
return false;
Julian E.
Dec 12, 2024 9:37 AM UTC
Hello @qs202310 ,
What version of cubeAI are you using. Try generating your project with the application template with the lastest version of cubeAI.
Can you share your model in a .zip file?
Your errors 48 and 19 correspond to initialization errors (in middleware/st/ai/ai_platform.h)
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
