Why does my NEAI always fail to generate benchmarks?
I used the simplest data for anomaly detection, but always failed to generate benchmarks. My setup screenshot with the data set is herelook forward to your replyQQ截图20240424210251.pngQQ截图20240424210243.png
Julian E.
First, have you tried closing and re-opening the studio again?
Else, can you send me the file nanoedge.log. In windows, you can find it by searching %appadata% in the windows search bar, then in workspaceNanoEdgeAI/logs
(something like this: C:\Users\YOUR_USERNAME\AppData\Roaming\workspaceNanoEdgeAi\logs)
On linux, you should be able to find the same folder: workspaceNanoEdgeAI
If you find a way to reproduce it, please let us know so we can fix it.
Best regards,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Woad1ngAuthor
Thank you for the response:
     First, I tried to reinstall the software, but it still happened.
     Second, NanoEdgeAI/logs is here.
     Looking forward to your reply!
Julian E.
The issue seems to come from the fact that you have special characters in your paths (Chinese characters if I am not mistaken).
We are looking for a solution, I will keep you updated.
Best regards,
Julian
Julian E.
I am glad it helped you.
We will work on our side to solve the issue you encountered in the next NanoEdge AI Studio version.
I hope NanoEdge will be helpful for your use cases.
Best regards,
Julian
