Nov 12, 2024 7:30 AM UTC
Where is "5 Emurator" at NanoEdgeAI V4.6.0
When I used V4.3.1 before, there was a "5 Emulator" step, but it doesn't exist in V4.6.0.
Is Emulator no longer available?
Julian E.
Julian E.Best answer
Nov 12, 2024 8:44 AM UTC
Hello @カッカ ,
I newer version of NanoEdge, the emulator is in the "Validation" step.
Simply select a library and click the "serial emulator" icon.
The idea is:
  • If you want to test a library using file -> do an experiment
  • If you want to test a library using serial -> use the serial emulator
More info here: https://wiki.st.com/stm32mcu/wiki/AI:NanoEdge_AI_Studio#Validation
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Julian E.
Hello @カッカ ,
The idea is:
Have a good day,
Julian
カッカAuthor
Nov 12, 2024 11:08 PM UTC
Thank you, Julian.
I was able to find the Emulator. And enter the previously used test data from the serial.
Also, input the test data file from experiment.
One more question.
Can I use V4.3.1 without updating to see what I've worked on before?
When I use NanoEdgeAI on another PC that still has V4.3.1, an update screen appears and I can only select "Exit" and "Download".
Julian E.
Nov 13, 2024 8:38 AM UTC
Hello @カッカ ,
If you disable your internet connection before launching Nanoedge, you should be able to use the previous version and see what you did before.
Have a good day.
Julian
カッカAuthor
Dec 18, 2024 1:52 AM UTC
When I use the serial emulator, I always have to change the COM and Baudrate settings.
How do I save my settings or change the default settings?
PS
I was able to get the rock-paper-scissors detection to work on the STM32H7.
Julian E.
Dec 18, 2024 9:12 AM UTC
Hello @カッカ,
Congratulation for the rock-paper-scissors detection project!
Concerning the COM and Baudrate settings, at the moment, it is impossible to save your settings. I transmitted your comment to the development team.
Thank you and have a good day,
Julian
カッカAuthor
Dec 18, 2024 11:45 PM UTC
Thank you, Julian.
Understood, I look forward to the development team's work.
I have one more request.
When running detection on the emulator, "Threshold:90" is displayed on the right side of the graph, but it hides the latest results and makes it difficult to see.
I think it would be better if you could change it to the left side.
Julian E.
Dec 19, 2024 12:32 PM UTC
Hello @カッカ ,
Thank you for the remark!
Have a good day,
Julian
