Jlee.91
December 27, 2022
Where can I check the result of ai_network_get_error()?
I used ai_network_get_error() and got the following results:
-> AI ai_network_run error - type=19 code=23
What does type and code mean here?
Where are the documents related to this?
I want to find the reason why the ai_network_run() is not working.
    fauvarque.daniel
    The error ty[e and code are described in the ai_platform.h file
    In your case type = 19 --> 0x13 --> AI_ERROR_INVALID_OUTPUT
    code=23 --> 0x17 --> AI_ERROR_CODE_INVALID_PTR
    Daniel
    ​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
