Zxiao.21
'utf-8' codec can't decode byte 0xab in position 4: invalid start byte
hi,
When I analyze the model, I always get an error.
How should I solve it?
Thanks!
    fauvarque.daniel
    Have you tried opening your model with a tool like Netron ? You can have this kind of error when the file is actually not a Keras saved model
    You can also open it with a text editor, the first characters in the file should be ‰HDF
    If the model can be viewed with Netron maybe there is an issue with the space in the path
    ​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
    Zxiao.21
    Zxiao.21Author
    Thanks for your reply.
    I checked these issues you said and they are all normal, eg, the model can be opened with Netron easily.
    Whether there are any special points to pay attention to in the STM32cube configuration?
    zyaol.1
    Do you solve it?
    fauvarque.daniel
    Sorry for the late answer I didn't see yours, can you share your model so we can try to reproduce the issue.
    zyaol.1
    this is my model.
