May 11, 2026 14:10 UTC
Toolchain not detected by Cube AI studio v1.2
I am trying to create a project with Cube AI studio v1.2.
My toolchain and libraries are well detected with Cube AI studio v1.1, and I can create a project.
However, it is not the case for the Cube AI studio v1.2. The toolchain paths seem valid, but when creating a project no IDE is proposed at all, as shown in the attached image.
Could you help me please ? No debug logs are generated.
Versions :
  • Cube AI studio : 1.2
  • CubeMX : 6.17
  • CubeIDE: 2.1.1
  • CubeProgrammer : 2.22.0
  • EdgeAICore : 4.0
stm-trtBest answer
May 11, 2026 15:42 UTC
Thank you for your response.
Updating proxy settings on each involved application has actually solved my problem.
I guess it couldn't download any updates, hence this bug. It has also solved the unwritten log files bug.
I have added the versions of each tools in the initial post, just if needed for the other users.
Thank you very much for your help !
hamitiya
May 11, 2026 14:37 UTC
Hello @stm-trt ,
Could you share what are the dependencies version you have for
- STM32CubeIDE
- STM32CubeMX
You also mentioning that  you don't have any logs. Does it mean that the folder C:\Users\<username>\.stm32cubeaistudio\logs is empty ?
If yes, could you check that all instances of STM32Cube AI Studio are killed in the Task Manager and the folder .stm32cubeaistudio is writable ?
Best regards,
Yanis
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
stm-trtAuthorBest answer
