TOOL ERROR: Error in computation of shapes
- 1 reply
- 270 views
I wanted to import a trained onnx into cuba.AI, but an error occurred. I have no idea where the problem lies. After troubleshooting, it was initially determined that there was an issue with the lstm part, but I have no way of knowing exactly where the problem is. I'm looking forward to your explanation. Here is my model code
import torch
from torch import nn
import torch.nn.functional as F
# from torchsummary import summary
from torchinfo import summary
## cnn extract features
class mfcn(nn.Module):
def __init__(self:(
super(mfcn, self).__init__()
self.stage1 = nn.Sequential(
nn.Conv1d(in_channels=1, out_channels=16, kernel_size=3, stride=1, padding=1, groups=1),
nn.BatchNorm1d(16),
nn.Conv1d(16, 16, 3, 1, 1, 2),
nn.BatchNorm1d(16),
nn.ReLU(True),
nn.MaxPool1d(kernel_size=2, stride=2), # 16*320
nn.Conv1d(16, 32, 3, 1, 1, 4),
nn.BatchNorm1d(32),
nn.ReLU(True),
nn.MaxPool1d(2, 2), # 32*160
nn.Conv1d(32, 64, 3, 1, 1, 8),
nn.BatchNorm1d(64),
nn.ReLU(True),
nn.MaxPool1d(2, 2), # 64*80
nn.Conv1d(64, 128, 3, 1, 1, 8),
nn.BatchNorm1d(128),
nn.ReLU(True),
nn.MaxPool1d(2, 2) # 128*28
def forward(self, x):
x = x.float()
x = self.stage1(x)
return x
class SimAM_module(torch.nn.Module):
def __init__(self, channels=None, e_lambda=1e-4:(
super(SimAM_module, self).__init__()
self.activation = nn.Sigmoid()
self.e_lambda = e_lambda
b, c, h, w = x.size()
n = w * h - 1
x_minus_mu_square = (x - x.mean(dim=[2, 3], keepdim=True)).pow(2)
y = x_minus_mu_square / (4 * (x_minus_mu_square.sum(dim=[2, 3], keepdim=True) / n + self.e_lambda)) + 0.5
return x * self.activation(y)
class lstm(nn.Module):
def __init__(self, inputs=128, hidden=16, num_layers=1:(
super(lstm, self).__init__() # 对继承自父类的属性进行初始化,并且用父类的初始化方法初始化继承的属性。
self.lstm = nn.LSTM(input_size=inputs,
hidden_size=hidden,
num_layers=num_layers,
batch_first = True,
# bidirectional=True
# self.dro = nn.Dropout(p=0.5)
self.lin = nn.Sequential(
nn.Linear(hidden, 7),
nn.Sigmoid()
def forward(self, x,batch_size:(
# batch_size = x.size(0)
x = x.view(x.size(0), -1, 128)
_, (h_out,_) = self.lstm(x) # _x is input, size (seq_len, batch, input_size)288*40*16
h_out = h_out.view(x.size(0),-1)
out = self.lin(h_out)
return out
class mfcn_simam_lstm(nn.Module):
def __init__(self:(
super(mfcn_simam_lstm, self).__init__()
self.mfcn = mfcn()
self.simam = SimAM_module()
self.lstm = lstm()
x = self.mfcn(x)
x = x.view(batch_size, 128, 1, -1)
x = self.simam(x)
x = self.lstm(x,batch_size)
return x
def __init__(self:(
nn.BatchNorm1d(16),
nn.BatchNorm1d(16),
nn.ReLU(True),
nn.BatchNorm1d(32),
nn.ReLU(True),
nn.BatchNorm1d(64),
nn.ReLU(True),
nn.ReLU(True),
x = x.float()
x = self.stage1(x)
return x
n = w * h - 1
hidden_size=hidden,
batch_first = True,
nn.Sigmoid()
return out
def __init__(self:(
self.mfcn = mfcn()
self.lstm = lstm()
x = self.mfcn(x)
x = self.simam(x)
return x
