AUzpa
Jul 22, 2019 4:23 PM UTC
Tensorflow Lite support X-CUBE-AI 4.0.0
I have noticed that the latest version of X-CUBE-AI (4.0.0) has support for Tensorflow Lite. Therefore I tried to analyze a SSD Mobilenet v1 network that I found on this blog post:
Link to blog post
Link to .tflite model
When analyzing the .tflite model, I have an error: "TOOL ERROR: Unkown layer type CUSTOM, stopping". I suspect that this comes from the post-processing operations that implement the non-maximum suppression.
Where can I see the list of supported TFLite operations? Also the list of supported Keras layers were removed from the Getting Started with X-CUBE-AI .pdf.
I couldn't find those lists elsewhere. I would really appreciate some help! Thank you and kind regards
    fauvarque.daniel
    fauvarque.danielBest answer
    Jul 22, 2019 4:31 PM UTC
    A lot of technical documentation has been moved in the pack itself under the Documentation directory
    You can access it through STM32CubeMX with the online help of STM32CubeMX.
    Leave the cursor on the "Artificial Intelligence X-Cube-AI" mode checkbox, you should have a tooltip with a link on the documentation
    You can also access it directly in your home STM32Cube/Repository/Packs/STMicroelectronics/X-CUBE-AI/4.0.0/Documentation/index.html
    ​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
    fauvarque.daniel
    AUzpa
    AUzpaAuthor
    Jul 23, 2019 8:04 AM UTC
    Thank you! Found it in my /root folder.
