FCata
July 24, 2019
Support for autogenerated code by STM32Cube.AI
Good morning,
I have created a project with CubeMX.AI based on an .h5 file constructed in keras following the steps shown on ST tutorial
https://www.youtube.com/watch?v=grgNXdkmzzQ (Getting Started with STM32Cube.AI).
Is it possibile to have an example showing how to exploit the generated code in order to solve
a generic problem of classification for a new sample of data?
Best regards
    Sbv
    Did you find answer to this question?I am also looking for the same.
    Romain LE DONGE
    If you're looking for an example of code using X-Cube-AI for a custom project you can check this GitHub link:
    https://github.com/ROC5COR/HousePricePredictionOnSTM32
    This project uses an old version of X-Cube-AI v3.3.0 but the idea is here.
    However the project is not a classification but a regression problem (House prices prediction) but you can just get rid of the output prediction and use a threshold to make it a classification problem with your own NN
    Hope this can help you :)
    Romain
