ramkumarkoppu
Apr 10, 2025 19:32 UTC
STM32-ISP-IQTune does not work on latest Mac OS
Downloaded latest version of  STM32-ISP-IQTune from the ST website today and installed it on my macbook, when I tried to launch the desktop application I get this attached error:
Apr 11, 2025 09:01 UTC
That error usually means that macOS has flagged the app as quarantined for security reasons (often when apps are downloaded from outside the App Store). You can remove the quarantine flag by running this command in your terminal
xattr -d com.apple.quarantine /path/to/app.app
Just replace "/path/to/app.app" with the full path of the application. This should stop macOS from blocking it, and the app should open normally.
Also, could you let us know which version of macOS you're using? That would help us understand this issue better. Thank you!
/Said
ramkumarkoppu
Apr 11, 2025 19:53 UTC
Hi Said,
By running xattr -d com.apple.quarantine "STM32 ISP IQTune.app" in the /Applications folder, I could open the ISP desktop application on mac. This is on the Apple Silicon M2 Macbook Pro with the MacOS Sequoia 15.4. Thank you.
TZiel.1
Apr 10, 2026 15:10 UTC
Fixed it for me too, but it shows up as the application image was corrupted. Think the package signing is possibly corrupted on ST's end..?
