AUzpa
Quantization-aware training
  • July 24, 2019
  • 1 reply
  • 1215 views
Is there a way to give X-CUBE-AI a model with quantized-weights? Right now the tool is able to do a custom post-training quantization for a given Keras model. However, what if we have a model that already has quantized weights (which is the case when we do a quantization-aware training with Tensorflow Lite for example)? Is there any solution/workaround to make use of "quantization-aware weights"?
Thank you and kind regards
    fauvarque.daniel
    Not in the X-Cube-AI 4.0.0 release, we only support TFLite in floating point.
    The next release in mid Q4 will add the support of quantized TFLite networks.
    Daniel
    ​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
